[Originally posted by Peter Nachtwey:
Not good enough unless you can measure over long periods of time.[/quote]
That's why I asked Alaric what his task rate was. The longer you make the measurement period relative to the sources of timing errors the more accurate you will be. But again, this only works for slow moving items that don't require a high speed update frequency.
One MUST control the interval at which the pulses are sent down the rod.
Is this necessarily true? Isn't it just as effective to know the actual time beween interrogation? Granted, this is just for measurement purposes and doesn't speak toward being able to use this value as part of a control system. But, strictly speaking, simply knowing the actual distance delta over the actual time delta should give you the same result as knowing the actual distance delta over a triggered time delta.
No one has mention recirculations yet. What are they? How do they adversely affect position readings?
The stress wave created by the magnetic interaction will travel both ways down the interrogation conductor. I believe when this wave hits the non-head end of the sensor it will be reflected and sent back toward the head end. The same will happen to the wave sent toward the head end. I believe the add mechanical dampers to the conductor mounts but you still need to wait long enough between successive interrogations to allow these to die out.
We use a 240 Mhz timer now.
I figured that would need to be pretty high to get the accuracies you need. I was thinking 100 MHz minimum.
There is also a 'beat' frequency type of error.
In a rotary cuttoff knife project I was involved in several years ago we saw a similar phenomenon with an incremental pacer encoder. The knife cylinder system would make this varying pitch whining sound. The pitch was related to line speed, not cylinder speed. The whine would go through several cycles between 0 and 1000 FPM, with cycles stacking up much more closely at low speeds. It really was kind of a cool sound. Made you think the goofy thing was haunted.
Keith
