possible or not?
bigrthanur
Mar 2007
Ohio
85
Does anyone know of a situation where a 24VDC photo eye would power up in reverse polarity. not talking signal wires just pos. and neg. being reversed.
Is this something you want to do or something you saw and are trying to explain?
If it relates to a specific product what is the manufacturer and part number?
If you want to make something so that it can't be hooked up with reversed polarity, how about a keyed connector?
I suppose one could wire a small relay in such a way that if the incoming voltage polarity is "corect", the relay does nothing but pass the voltage to the circuit board. But if polarity is reversed, the relay energizes, and the contacts are wired to reverse the polarity at the output of the relay so the circuit board never knows the difference.
I've not sketched it out, but my mind's eye can see it working.
Bill
Why i am asking is our plant manager asked the question to a mechanic about a photo eye being wired correctly. Pos. to Pos, and neg. to neg. He stated that he has seen before a photoeye wired backwards and still worked but had wrong voltage and would not give an output.
I disagree with him and was thinking he was talking about NPN vs. PNP. He said NO it is possible to wire a 24VDC eye backwards and eye will still show lights as "working" but will give wrong voltage on output.
bigrthanur,
I do not know what your manager saw, but perhaps this is a possibility.
Banner makes a photo eye series (ez beam) that has two diferent configuations depending on how it is hooked up. One configureation is with a NC and a NO output. But if you reverse the polarity on the wires (blue to positive, brown to negative) then one of the outputs is an alarm output to warn you if the excess gain goes below 1.5 . The other output will be NO.
So if he connected to the alarm output the photo eye would appear to work (by looking at the indicator lights) but there would be no change of state on the alarm output if the excess gain were outside of the .9999999 to 1.5 excess gain area.
brucechase said:
If it was me, I would just wire one up in front of the boss and see what it does.
Thought about it but He would just make another excuse to how he was right.
Anyway i am putting my 2 weeks in on tuesday. I GOT THE JOB I HAVE BEEN WAITING FOR. I am now officially a robotics engineer!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hi mildrone,
sorry i wasn't clear, i was asking bigrthanur. there is plenty of products on the market and they may behave differently. it would be good to know what product we are talking about.
for example reverse wired reed switches may work but not lit the indicator.
in this case we are talking about photo eye, chances are the boss is recalling case where the output configuration of the sensor didn't match the plc input so even if the sensor is working, plc sees no change (PNP/NPN mismatch)
I believe this is what milldrone is speaking of
http://info.bannersalesforce.com/xpedio/groups/public/documents/literature/116157.pdf
As you can see from the connection diagram the power polarity is reversed in relation to the blue and brown wires when the alarm configuration is desired.
If the PLC input was connected to the NC (white output wire) and the polarity was switched on the blue and brown wires. Then this output would only turn on when the alarm condition exsits.
The sensor would appear to function according to the led indicator lights but the PLC input would not change because the was connected to the alarm input. Then if the plant manager switched the power leads to 24V+ on the brown and 24V- to the blue, the output would change just like the indicator lights on the photo eye.
cameltoe: The drawings you have there, I believe that thoes are two different part numbers one part for an alarm and one with out an alarm. Am i correct?
bigrthanur,
No, all of the EZ-Beam series, (DC only) have this feature
The S18 series (DC)
http://www.bannerengineering.com/en-US/products/16/Industries/660/c/157/S18-DC
The T30 series (DC)
http://www.bannerengineering.com/en-US/products/16/Industries/660/Food-Beverage/176/T30-DC
T30SN6LP​
T30SN6LPQ
T30SP6LPQ
S30 series
http://www.bannerengineering.com/en-US/products/sub/171/S30-DC
S30SN6R​
S30SN6RQ
S30SP6R
S30SP6RQ
Q40 series (DC)​
T18 series​
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
248
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
365
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
199
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
845
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
300
