matlark Member M Join Date Jul 2011 Location KY Posts 102 Oct 19, 2012 #1 Without utilizing vfd's. Is there some component out there that will enable the conversion? Thanks
bernie_carlton Lifetime Supporting Member + Moderator Join Date Apr 2002 Location Yakima, Washington Posts 6,413 Oct 19, 2012 #2 Simple, just hook up between only 2 phase leads. It fulfills what you wrote but I'm sure that's not what you meant.
OkiePC Lifetime Supporting Member Join Date Mar 2005 Location ENE of Nowhere Oklahoma Posts 11,794 Oct 19, 2012 #3 matlark said: Without utilizing vfd's. Is there some component out there that will enable the conversion? Thanks Click to expand... I am with Bernie. Remove a phase and you have it...but that's probably not the whole story.
jkerekes Member Join Date Aug 2007 Location NJ Posts 2,363 Oct 19, 2012 #4 matlark said: Without utilizing vfd's. Is there some component out there that will enable the conversion? Thanks Click to expand... Yes.
bernie_carlton Lifetime Supporting Member + Moderator Join Date Apr 2002 Location Yakima, Washington Posts 6,413 Oct 19, 2012 #5 Is this the same application in your thread which you started March 12th of this year?
