Possible to use 2711P-T6C20D8 HMI with Micro850?
technolog
May 2015
Ohio
320
We have a project coming up which we need to do as cheaply as possible. We have a used 2711P-T6C20D8 HMI. Is it possible to use this with a Micro850 or ML1400, for that matter?
Cheaply and AB doesn't compute, lol.
Is that HMI model you stated the PVP 6? The 7 is the current series and is probably a few bucks less. The 1400 works well with both, never tested the 850.
That's a pretty expensive HMI, unless you already have it I'd go for something like 2711R-T7T which definitely works with 800 series PLC (HMI programmed with CCW)
Edit: oops re-read, you have one used, never mind!
Apologies for the late response. I was sick for a while and this was sorted out by someone else. We eventually decided to use an Automation Direct EA3-T4CL with an ML1400.
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
240
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
358
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
190
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
835
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
297
