Power consumption of VSD drives in the off-state
Binaural
Jul 2005
Sydney
366
This may seem like an odd question, but I have a few large motor control cabinets that need to be powered up simultaneously for customer testing. Each MCC normally has a single 1000A supply. I need to size some circuit breakers to power up each of these cabinets, but since this is only for testing I would like to use small ones.
I can estimate the power consumption for everything well enough except the VSDs - not surprisingly, the manufacturer doesn't tell you the power draw when the VSD is not driving a load. Does anyone have any information they could share here? The drives are Allen Bradley Powerflex 700s.
I just checked our PF700 125HP drive. It was pulling about .3-.5 amps per leg at Idle.
During cold startup I saw a spike of close to 18 amps per leg. But this probably changes slightly depending on the size of the drive.
I was wondering if anyone had any insight on to how i could monitor and possibly graph Amp draw on our Powerflex 525 Drives. These drives are...
1,757
Hello, I want to ask about the power consumption of the 1769-Pb4: It is written that the input power consumption at maximum load is equal to...
1,820
Hi All, I'm having some trouble on determining the total power consumption of the following I/O modules: 1769-OB32,1769-OF8V, 1769- OW16...
2,643
Hello We have a 3 phase machine where we need to log the power use during every run of a process. Each run can last anywhere from 30min to 5...
2,291
Dear, I am computing a rough estimate on the power consumption for UPS for a PLC cabinet, the UPS will be also serving two flowmeters (each...
1,578
