1769-PB4 power consumption
poi123
Dec 2017
Jamaica
Hello,
I want to ask about the power consumption of the 1769-Pb4: It is written that the input power consumption at maximum load is equal to 100W. However, as I can see from its datasheet http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1769-in028_-en-p.pdf (page 29), the pb4 can supply at 5Vdc 4amps and at 24vdc 2A. Doing a basic calculus, the output power of the pb4 is equal to 68W however its input consumes 100W. why there is a difference between the input power and output(32W)?
Thanks for your help
The output numbers are probably being conservative and there is always wasted energy (mostly in the form of heat) in a power supply.
The power consumption is probably also being conservative (err on the side of caution) in that the supply may draw up to 100W, but in reality in a typical application you will likely measure much less.
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
I have a CompactLogix 1769-L31 and need to communicate with it. I only have studio 5000 on my computer. However, when I try to start a new project...
398
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
256
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
111
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
486
