Power Cycle Calculations Help
Tim Ganz
Dec 2010
Dallas, Texas
701
Trying to understand a power study done a few years back on one of our lines. It says there were volatge sags on one phase (277) that went as low as 244 and lasted a range of 1/4 cycle to 1 millisecond?
If I understand correctly on 60Hz power that 60 times a second and one cycle is 1/60th of a second which would be 16.6 milliseconds per cycle correct? Which would make a quarter cycle 4.15ms?
So it lasted 1ms to 4.15ms?
Seems as if they would have worded it differently - 1 mSec to 1/4 cycle (from lowest to highest). Or, even 1 mSec to 4 mSec.
Maybe you could contact the reporting person and ask?
I'm not really a power guy but it seems odd to apply an RMS value to an event that doesn't last at least a full cycle. Is that normal? I've never had a power analysis done.
Keith
Hello PLC friends. I've been going through a saga of diagnosing and fixing an old PLC setup that I inherited. I am learning as I go. Initial...
353
Hi everyone. I have an issue with an Allen Bradley PLC model 1769-L30ER. This PLC had a previous program with a different IP address but when I...
542
My Panelview plus 700 HMI stopped working and I replaced it with a new one. Moved the sd card from the previously installed panel to this one and...
16
1,022
Hi everyone, I recently put in a 1769-AENTR, and where it is installed has had a couple power outages. Every time when the PLC comes back online...
701
We have a devicenet consisting of 15 PF755 drives in a centerline MCC, and on a separate trunk cable coming off the scanner, a single PF525 in a...
352
