Power Flex 40 won't start from keypad
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello All. I have a Power Flex 40 that I am trying to run locally just to test a motor. I have a jumper from Terminal 1 to 11, P036=0, P038=0.....the respective LED's turn Green however, when I press the start button on the keypad the "Run" LED blinks real quick but doesn't stay on. No faults appear on the VFD either. Any ideas would be great. Thank you
I would do a factory reset of all the parameters.
It could have been setup for external control through Ethernet, Modbus or need an atypical input to run.
EDIT: I remember replacing a Lenze drive a customer bought a used one and had a printout from the machine OEM of about a dozen parameters that were not factory default, but the one they bought was changed for Modbus control and there was no 'Factory Reset" so I had to go through a couple hundred parameters and manually change them all back to the factory setting, or the OEM setting for the few.
Power flex 525 won't power on incoming supply is ok. 5 year old.
1,657
I replaced a SMVector Lenze AC Tech drive with an AB PF40. From the keypad I can start it up just fine and it ramps up to the Hz requested. When...
3,288
Hi guys, How to check whether the PowerFlex 753 50HP, 460VAC is good or not. It won't power up. I have 460VAC going to the drive. I checked fuses...
4,840
I have a Flex I/O IE8H card and it will not power a loop powered Siemens level transmitter. I can simulate with my process meter just fine but...
3,674
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
117
