PowerFlex 753 won't power up.
tjntjntjn
May 2012
USA
93
Hi guys,
How to check whether the PowerFlex 753 50HP, 460VAC is good or not. It won't power up. I have 460VAC going to the drive. I checked fuses three times. The original ones seemed to be OK but I replaced them to avoid this mistake.
Normally when PowerFlex "blows up" I can smell it but nothing on this one. I Don't smell anything, don't see any signs of anything being fried.
Any suggestions>
All help is appreciated. Thank you
If there's power on the line inputs, and it's not powering up. Then the drive is typically no good. You don't always have a burnt smell on a failed drive.
Is the connection to the faceplate OK? Fans turn on?
You can check if the converter part is working by checking the DC bus voltage with a multimeter. At 480 Volts AC you should get somewhere between 650 and 680 Volts DC.
Assuming this is a Frame 5 drive, (50HP Heavy Duty rated), the rectifier at that size uses an SCR based bridge for precharge mitigation rather than precharge resistors. So because SCRs are active devices, they have a firing board that ramps the voltage when you initially apply power to the drive. If you lose the firing board or the line sensing circuit for it, you get no voltage on the DC bus. And because the drive derives it's control power from the DC bus instead of a separate power supply, you don't have a display to tell you that's what's wrong. Hence the meter reading as suggested.
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
108
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,360
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
457
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
563
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
722
