Power flex 525 control module swap
Snap25
Dec 2014
Michigan
237
Quick question.. I have a power flex 523 (not 525)
The control module (cat # 25A) looks identical, just doesn't have the Ethernet option.
Is the control module 25B for the power flex 525 interchangeable with he 523?
I'm assuming it is but wanted to verify before ordering one. Thanks
They are interchangeable in that the base unit doesn't care, it is coded to tell the control module what it is, but is agnostic as to whether the control module is a 523, 525 (or 527). The control modules are not the same though, there are more functions and more I/O in the 525, it's not just the Ethernet port that's different. So if you have a 523, you can use a 525 control module and just end up with more than you had before, but if you have a 525 and try to swap out the control module from a 523, you may end up short.
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
136
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
200
hello everyone. I have a 525 VFD that works, the screen shows the output voltage and the output frequency but in UVW I do not have voltage...
194
I have this 525 that i am controlling it via ethernet. I needed to jog the drive using a start PB. when the button is pressed, the drive moves and...
686
Hi All, While Replacing a VFD in breakdown condition which is the right and easy way to replace the drive quickly. We are working with Plant PAX...
1,529
