Power flex 525 ethernet functionality lost
dcam
Apr 2012
Merced Ca
161
We are intermittently losing Ethernet function on our 525"s. Not sure why? Any ideas would be appreciated. I work in an old cheese plant with poor network routing / poor wiring practice. The failures seem totally random.
I realize you know that the wiring and routing is contributing to your network reliability problems.
The diagnostic web pages in the PowerFlex 525 might be able to show you if the problems are in the link between the drive and the switch it's attached to (if there are CRC errors or framing errors), and the web pages in the ControlLogix itself will tell you the same for its link to the nearest switch.
But in between those switches.... that's where your network infrastructure is what you need to focus on. Start with a diagram and figuring out which switches can give you diagnostic information.
And are you using managed switches? If so, you should be able to see where the signal gets lost. If you are not using managed switches, that’s something to consider.
I have an issue with Power Flex 525 during running processing, the VFD stopped suddenly while the PLC and VFD connection ok, VFD does not have any...
127
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
187
hello everyone. I have a 525 VFD that works, the screen shows the output voltage and the output frequency but in UVW I do not have voltage...
185
I have this 525 that i am controlling it via ethernet. I needed to jog the drive using a start PB. when the button is pressed, the drive moves and...
678
Hi All, While Replacing a VFD in breakdown condition which is the right and easy way to replace the drive quickly. We are working with Plant PAX...
1,520
