power supply fault
porky
Oct 2002
Maia
76
Has anyone ever experienced an intermittent fault on an AB Plc ..due to a faulty power supply ?
Processor fault
I experianced a processor fault in my last AB job .It was very strange when i try to down load the program while the key switch in the remote position a communication error occured ,the fault led flashing and the RSlinx indicate that the processor in node 1 is faulted .In this case when i try to connect again to the PLC rither by download or go online i have a message the no responce from the processor.This requires me to remove the power from the PLC and switch it on again and restart my computer so i can reconnect to the cpu.
in this condition the OPC was running as well as a visual basic application .any explanation :unsure:
---Power supply fault---
Just an info,
In SLC you can let RSLogix 500 to calculate whether the power supply used is sufficient or not.
Go to I/O Configuration tab and click on the "Power supply" button (assuming the all of your modules have been selected in the I/O configuration).
This will open up a Power supply loading form, select your power supply model, in the message box, a warning is displayed if your power supply used is under sized.
This calculation in the software is just for "information" for you to size up your power supply, it don't remedy errors.
Good Luck
I've seen this happen because of poor supply power quality.
A number of my customers spec Constant Voltage transformers to supply any PLC power supplies.
They're quite a bit more expensive than normal control transformers, but cheaper than fried/locked up PLC equipment.
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
215
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
595
I have Rhino 120 to 24 dc power supply and it has 2 Positive and 2 negative terminals on the DC side but no ground terminal. Should I connect one...
443
We've still got a ton a PLC 5's installed and running. We lost a 1771-P7 Series B power supply. There are a lot of 1771-P7 series D power...
244
Long ago, it was often a customer spec to always use a transformer for isolation of the control circuit from the rest of the equipment. For 24vdc...
692
