Power supply in Modbus network
SORZOM
Nov 2007
Irvine
Hi Everybody!
Do we always need dedicated power supply in a Modbus network? I'm going to design a Modbus network comprising 15 slaves connected to a AB Micrologix 1100 and couldn't find enough info from Modbus.org and Mirologix manual to verify whether or not I need a separate power supply.
Thanks in advance,
The confusion came from Modbus manual (Ver. V1-02 available on Modbus.org) where it says the 5..24 VDC power supply is an optional electrical interface which may be added in a 2-wire Modbus network.
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
206
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
588
I have Rhino 120 to 24 dc power supply and it has 2 Positive and 2 negative terminals on the DC side but no ground terminal. Should I connect one...
439
We've still got a ton a PLC 5's installed and running. We lost a 1771-P7 Series B power supply. There are a lot of 1771-P7 series D power...
241
Long ago, it was often a customer spec to always use a transformer for isolation of the control circuit from the rest of the equipment. For 24vdc...
687
