power supply need help
Unregistered
Guest
U
hi,
can any one tell me if the Sitop power supply by siemens model 6EP1336-2BA00.rated 120/240VAC, 8.0/3.3A on the input and 20A, 22.8VDC-26.4VDC on the output. is compatible with a simatic s-300 CPU314-IF PLC? thanks
I don't know the 314-IF, I guess it must be an older model, but since the PSU has exactly the same dimensions as the 300 series modules, it looks as though it was specifically aimed at this family. Unless the 314-IF has any peculiar requirements (such as 5V supplies for built in encoder inputs) I can't see why you shouldn't be able to use this supply, at least as the main supply for the 24V requirements.
There is no reason why you can't use this power supply to power your PLC with (as Roy pointed out). I use these a lot of the time instead of the PS307's.
One thing to note, they will not fit on the standard S7-300 mounting rail, they are made to fit on standard DIN rail (36mm 'top hat').
Paul
I am facing a very strange issue with the AB hardware, specifically with power supplies. The problem started when a power supply in a 4 slot...
4,134
G'day, I'm trying to find a definitive answer to the following. If an IM365 interface module is fitted in an expansion rack can a power supply...
5,888
I hope it's ok to post this.... Just wondered if anyone has a spare 24VDC, at least .75amp, DIN mounted power supply that they would be willing to...
6,247
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
221
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
601
