power supply problem
spanky
Nov 2009
Edmond Ok
I have fanuc 90-30 plc. On several occasions I get no power lights on the front of the power supply of the plc with appropriate input voltage being supplied. The previous occasion the equipment sat idle over the weekend. Upon monday morning the plc was up and running. Could the power supply on the plc rack be defective or possible internal thermal switch within the power supply.
I'm not aware of any thermal cutout in the 90-30 power supply, but there is a fuse on the incoming line. If that's loose in the holder or the filament inside the fuse is loose, it could cause the problem you're seeing.
The "PWR" LED on the power supply is an indication that power is present to the module.
We have also had this problem with a GE 90-30 power supply with the fuse coming loose. I have found that the power supply does not do very well in a location with vibration such as on a machine. We have also had problems with a capacitors breaking in the power supply. Is your Ge 90-30 in a location with vibration?🤾
Hi, Does anyone has experience about switching power supply problem ? I have power supply unit SITOP with output 24Vdc, 10A. At the moment, this...
8,296
Hi, I am using controlLogix 1756-PB75R powersupply module for a control logix chassis. At site the power supply is fed from a retfier which is...
3,012
hi :) i have a slc-500 series A . my problem as following. ** our power supply source is dc battery charging with solar cells, all over the...
12,174
I have the power supply in the link below. If we want a breaker to isolate and protect the input side how would I size that correctly being 120...
204
I am looking for power supply that I can mount on vertical DIN rail, and when mount that way is =< 4" wide. this is what I have now.... this is...
21
584
