Powerflex 525 USB config
Snap25
Dec 2014
Michigan
237
Is anyone else having issues getting the .exe to load or do anything when plugged in? I’ve tried multiple computers with multiple different 525s.. when I click on the E: drive in the tree, it will load as long I’ll let it then crash.
I've had no luck with Windows 10. Windows 7 works like a charm. I'm guessing RA needs to do a firmware update to make it compatible with Win10.
OG
Never tried the USB config, but CCW is free to download and pretty easy to get a PF 525 set up via Ethernet. Maybe worth a try.
Is the firmware in the PowerFlex 525 not compatible with Windows 10? I like to configure these ahead of time so I am not fumbling on the job...
2,445
I'm trying to configure a bunch of VFD HIMs via the USB connection on the 525s. Windows will only show it under "Other Devices" as a USB MASS...
11,702
Has anyone used this? The idea is that you can connect your computer to the control module of the drive with a USB cable, and upload/download...
6,524
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
238
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
248
