Powerflex 527 - Changing Firmware
Rob S.
Sep 2008
Maryland
739
Good Afternoon ,
I'm going to change the firmware on a Powerflex 527. I have a few questions .....
- Can I change the firmware while it is online ?
- The ControlLogix Logix that it is running off of is version 28. What is the
highest the Powerflex 527 can be flashed ?
- Also ,should I use the regular ControlFlash or ControlFlash Plus to flash this
- Also , I tried to use ControlFlash and could not locate and Powerflex Drives
in it's library . How do I drill down to the drive I'm looking to flash the
firmware ?
Thanks so much ,
In the RA Compatibility and Downloads Section, use the search terms "PowerFlex 527" and you'll find the firmware for 1.007, 1.008, 2.001 and 2.002, as well as the Add-On Profiles that match each.
https://compatibility.rockwellautomation.com/Pages/Home.aspx
I don't know the precise Studio 5000 minimum revision for compatibility with those AOPs. If it were me, I would likely be conservative and update only to the highest sub-revision for the current Major Revision that's running on the drive.
You can use either version of ControlFlash; I would stick with the ordinary classic ControlFlash and not try to get fancy. I also prefer to inhibit the I/O connection to the controller, or isolate the drive on a private network, when doing firmware updates.
Hi all, I am having issues with a Powerflex 527 STO. I am hard wiring a safety relay (guard master MSR27TP) to S1 and S2 and also the common to...
1,801
I am trying to setup the new powerflex 527 to use for training purposes but it wouldn’t let me to finish adding it to an IO and I would get an...
1,199
I swapped out a PF 527 drive that has been giving me occasional faults. I replaced with a new 527, assigned its IP and gateway and cycled power...
2,031
I've got motor that ran fine for years, but now it's sarting to overshoot its target position a few times a day. Is this indicative of a motor...
24
5,757
Sorry its probably a stupid question. I have version 1.008 PF527 which going to be replaced with a FW Version 2.001 Unit. I have version 32 logix...
1,496
