Hisma
Hey so I have an issue that is driving me insane. I have 6 AB powerflex 527 drives configured in a DLR network over CIP Safety. They go back to a EN2TR card that's configured as the ring supervisor.
What has been happening since the system was commissioned is that randomly one of the 6 CIP Safety-based STOs will randomly drop out (lose comms) for a few milliseconds, which is just long enough to trip the system those drives are controlling. Suffice to say, this level of instability is completely unacceptable.
I have some possible theories as to what it could be, but I'd like to know if others have experienced this.
My theories -
the networked STOs are using shielded CAT6 cable, but they are NOT VFD rated cable. Has anyone had issues with VFDs causing network drop-outs on ethernet networks? I mean, VFDs do put out a lot of high frequency noise, and they do make VFD-rated (high insulation) ethernet cables. The problem is I need to solve this issue ASAP, so if this IS the problem, is there any temporary solution I could use to insulate the existing cables, maybe tape or flex conduit or something?
Right now the time sync on the input is set to 10ms, which I think is the default. That's quite fast and could be causing packets to drop if the network can't keep up. I'm wondering if I should increase that time. I'd be curious if anyone has any insight on what a good time sync to work with would be. My safety task is 25ms, so I'm thinking I could increase it a bit and not have any impact as long as its below 25ms. Thoughts?
Any help would be greatly appreciated. Thanks!
My theories -
