Guys,
I have a powerflex 753 25hp that we installed replacing a powerflex 700 25hp. we had a short that took out the drive and we installed a powerflex 700 20hp just to get by till we got the 753 in. the 20 hp seemed to work fine except when we got into a heavy load and then would fault at about 29 amps. when we installed the 753 everything seemed ok but started getting a "Motor Overload Fault" and shutting the machine down. Parameters in the 700 25hp and the 753 25hp. are the same but it is kicking out at around 23 amps. motor is 460 V rated at 25hp 26FLA. Has anyone run across this issue with this drive.
Thanks in Advance,
Eli
Thanks in Advance,
Eli
