PowerFlex 753 - I uploaded a similar drive application,I would like to download to753
Rob S.
Sep 2008
Maryland
739
Good Evening ,
I have a PowerFlex 753 that I need to replace . There will be a 20-750-S and a 20-750-ENETR installed . I uploaded a similar drive , and would like to download this to the new drive. Do you think I would have any issues downloading to this other drive ? I guess I would need to change the IP Address in the uploaded ( similar drive ) in the 20-750-ENETR parameters , correct ? I am using CCW . I took notice that in the top right corner there is Ethernet path with the IP Address . After clicking on that , there is an option to clear the path. Do you folks have any thoughts or procedures that you would recommend ?
Thanks so much for your help .
I've had issues with PF 753 and 755 parameter files due to firmware, as in the backup was a prior firmware revision to the new drive. At least if you have a backup you know what the previous parameters were and can program the new drive to function as the old. The 750 series are great, versatile drives, but they can be a headache...
Yep, the firmware versions must match. You can look at the Firmware Rev on the one you are copying and hopefully make the new one match, but if the age is vastly different, there may have been hardware changes that might affect it. You can check it yourself here, or call AB Drives Tech Support and ask, that's what I do.
Thanks. The old drive and project are 11 , and the new drive is 13.002. I tried using " Match Drive" but that procedure failed . The software recommended " Create Database " . That procedure allowed me select 13.002 . I guess the next step is to download the program tomorrow morning .
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
110
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,370
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
458
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
570
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
726
