Powerflex 753 Position Control
blystovski
May 2011
Ohio
Has anyone done point-to-point or absolute position control using an AB Powerflex 753 drive? If so, what are the key points to making it work? With P2P, how do you program the the two "points" in the drive? With absolute, is the position setpoint simple a number of encoder pulses? How do you determine where the "zero" is?
Thanks for any help guys!
~John
Are you talking about a single stand alone drive or multiple drives?
If you are trying to do a coordinated system then that is not what the 753 is geared for but the 755 is. That is the primary difference between them.
753 standalone
755 system Drive
Are you using in conjunction with a plc or are you trying to do it in the drive logix?
You also want a high res encoder as good as you can afford. The higher res the encoder the better the control is.
Hi everyone, Is it possible to position with third-party servo motors using PF 753 or PF 755 AC drives? I know torque and speed control are...
5,178
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
124
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,398
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
474
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
597
