pressure control valve
shkoko2000
May 2011
cairo
296
i have separator and at this separator blowdown valve and at the downstream there is pcv (fail open) found and after that filter is found when we want to depressurized the filter the flow goes in the reverse direction what is the effect of this reverse direction at control valve and its componant(seat,plug nad cage)
If I understand you correctly you have a filter downstream of the PCV in a separator blowdown line. When you backwash the filter you want to know that happens at the PCV. Is this correct? You haven't given us any brand/model information on the PCV, but based on my general experience with them most PCVs are not going to function in a reverse flow condition. You might need to place a bypass valve in a loop parallel to the PCV. When the filter is backwashed open the bypass valve. A check valve may be suitable as well, you'll have to decide if that is appropriate.
i have reverse flowed these valves in the past for short periods of time, you just loose some control over it if you were trying to do pressure control. You can always look into a V ball which i use a lot of (fisher) and are rated for bi-directional flow.
Second guessing myself here, need someone to either tell me I'm wrong or confirm that my thinking is correct please. I have an equal-percentage...
2,757
Good Morning, This may be an easy question for some...but I'll need a little guidance. I have a project where under a particular condition I...
1,612
Hi All I have a pressure control valve and current to pressur transducer from Fisher coontrols. The problem is PLC sends the signal to...
6,251
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,959
Hi I am a beginner and therefore have problems with M221 PLC programming. I want to program the PLC so that the pressure increases slowly (I...
2,260
