Problem Device Tag String in SLC 5/03
leo3886
Apr 2009
Ha Noi
Hi everyones,
I creat a tag String (example ST10:1) in PLC 5/03 OS 302, and a device tag string in Rsview32,. I use String Display in Rsview32 to show this device tag String in PLC, and the Program work well, but when i use the String Input to set value string for this device tag string, but the Program stop , and i can't exit Rsview32,because when i press button "X" to exit Rsview32, Rsview notice "Cannot close editor while download is in progress,please wait and try again". I don't know why
Ciao guys, I'm not used to program on Siemens PLCs, but sometimes I have to. I'm experiencing a strange problem when I try to connect to a PLC...
3,892
I have wincc flex 2008 project made with wincc flexible 2088 sp1 project hmi device is simatic pc panel 19" I want to change hmi device to run the...
17
5,288
I made a hardware configuration and I used IM151-8 PN Cpu and connected two ET200S stations (IM151-3).When I want transfer to ET200S first.I am...
1,779
Ok I have a communication problem between the server and the device.Maybe someone might know the solution here or have come across this problem...
2,613
hi friends I 'd like to work with cpu 314 2dp(6ES7 314-6CF01-0AB0)but it is not in simatic manger V5.1 I found its gse file in siemens site...
3,091
