Problem getting decimal value to ineger file using NI8
zahidraza1212
Feb 2010
pakistan
m using AB SLC-500 PLC and the processor is SLc 5/03.i want to implement the PID control on the bytronic inverted pendulum using this PLC.As a start,i m trying to understand the analog I/O's.i selected the range from 0v-10v from configuration and selected the channel-1,activated the channel and pressed ok.then the COP instruction appears on the Ladder program on its own.i applied the voltage from power supply to 0+ terminal of NI8.and varied the power.before this i used the SCP instruction in the manner
input I:4.0
inputmin 0
inputmax 32767
scaledmin 0
scaledmax 100
output N7:10
but no value i examined to be coming in the N:7 file.if any one can help me plz reply me very soon.
The COP instruction is usually placed automatically when you have completed configuration of your module (Channel Enable/Data Type etc.) and writes all of the parameters on the first pass to your card.
Hope this helps.
Rob
i have posted the .RSS file already.i will try tomorrow by examining the dip switches in the card.i think if their position is not right.thanks Blamb,Kidblue,Jstolaruk, and others for giving me useful directions.
m using AB SLC-500 PLC and the processor is SLc 5/03.i want to implement the PID control on the bytronic inverted pendulum using this PLC.As a...
2,882
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,448
Hi guys I was wondering if you guys were able to help a beginner in the field. I am currently trying to get a virtual CAM to run but for the...
1,942
I have FactoryTalk View communicating to my micrologix 1000 plc using RS Linx Classic and i get all my integers, bits, timers, counters, etc but I...
2,542
Hello Can anyone help me I am fairly new to Omron and have not used it for about 2 years I am trying to get online to a Omron CQM1 PLC CPU21 I...
3,616
