Problem going online to GE VersaMax Micro with Proficy ME
Assuming that you were going to download, the program back into this Micro, I assume that you have the program. If so you should be able to open the hardware configuration and see what the port(s) are set to. Match this in Proficy ME.
I did that exactly, Russ.
Still cannot connect.
o_O
Should I have an SNP ID in the property inspector?
If so, what should it be?
Thanks for the help.
Proficy will work with or with out an SNP ID, but it too will be in the project that you need to download to this unit.
I keep forgetting this.
In the Navigator window of Proficy ME click the "Utilities" tab and Double-Click "Serial Communicaton Utility" This brings up a handy little program that will search the assigned port for an SNP device and tell you what its serial parameters are. It will help if you have known good cable, USB adapter, PC port and PME installation.:)
Hi guys, I am new in siemens software and trying to go online with a plc S7 300 via router, this is what i have been doing, first i connect my...
1,775
Hi, Im pretty much inexperienced with Control logix platform. We have a new machine that has controls done with it. Problem is I cannot...
1,624
Its great to be able to contribute something for once after having used the forum. ANyhow, a particular 2 * 7 rack SLC system has been a...
2,309
I have arranged a spare PLC5 for our machine which already has PLC5. After receiving, I set the dip switch settings same like the original...
5,072
Dear PLC Experts, I am trying to go online with Omron Sysmac CPM2A PLC with CX-Programmer V 6.0 on Windows Vista Operating System. It gives...
9,770
