Problem locating the consumed tags in LOGIX5000 project
nail9394
Feb 2010
Ontario
I can view all Produced tags list in the project from Logic-->produced tags, can someone help me on how to view the consumed tag list ? Thanks in advance
Depending on the version, at the top of the controller tag window there will be a drop down selection, I think it says "show" next to it. That should have a selections of Produced, Consumed and Unused. If you don't see that, specify what version you are using.
Thanks dmroeder, I see it now
If you look at controller tags, then the alias and base tag columns you can see if any tag is setup already as produced or consume tag
Produced tag will show a path in Base Tag if setup.
If not there is a pdf that you can look at from AB that shows the steps to setup.
22
451
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
45
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
193
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
149
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
160
