Problem uploading a PBA application
Broken Hippy
Feb 2009
Derby
This is probably too simple to ask, but I am a novice with Panelview.
I have downloaded an old PVA application from a panelview 900 and have reworked it. Saving it as a PBA application.
When I upload it to a new PV100 during validation it wants to save as a PVA app and therefore looses all the colours etc.
How do I go about solving this?
Many thanks in anticipation
D Clark :)
D Clark :)
When you reworked it, did you also change the type? See picture below.
Well I have to ask. Are you sure its a color PV1000. What is the complete catalog number? Don't guess look at the back. It might be possible you did not get what you ordered.
Yes it's a colour. I can change the colours directly onto the PV, with the laptop, just that the saved software reverts to a PVA file when going through the validation process.
CAT No - 2711-T10C1
Dave
Ok I'm not sure what is causing your problem but how you save a uploaded file from a PV can cause problems. See PDF below for more on that. It can't hurt to try. You will have to start over with a new upload from your PV900.
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
115
I'm starting learning ladder programming. I bought the FX3U kit + coolmay HMI from aliexpress. I'm doing basic testing and uploading codes. I...
57
3,929
Hi dears I am facing problem during program upload on S7 200 (226 cpu)microwin 4 sp9 closes on 100% I try to upload data blocks, its ok, System...
2,454
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,859
413-5H redundant system I can get online, monitor, even edit but cant upload to the PG, tried creating a new project, asks for rack/slot/ but...
1,844
