Problem with ethernet communication micrologix
aryautomation
Nov 2006
texas
34
🔨 I am trying to connect my computer to micrologix 1100 ser A via ethernet switch. I am using rslinx 2.53.00.05, my computer IP address and subnet is 192.168.1.101/255.255.255.0
plc ip and subnet are 192.168.1.104/255.255.255.0 (they were entered into plc using serial connection)
I tried two different drives by maually entering the ip addresses ip addresses(ethernet devices) and ethernet/ip driver. All I get on the PLC in RSWHO is a big yellow question mark with a red x on it. ANY HELP WILL BE GREATLY APPRECIATED.
Bootp is unchecked in plc channel 1. I am not familiar with pinging. how do you do that?
Open command prompt and type in "ping xxx.xxx.xxx.xxx"
where xxx.xxx.xxx.xxx isyour actual IP adres to ping.
I think commnd prompt is under accessories.
Do not include the "" part.
Since your going from an ethernet switch then you should not need a crossover cable. But to elimiate the switch I would plug directly into the PLC with a crossover cable then ping it.
Also when you are entering the adress into RS Links make sure you do not use leading zeros.. IE 192.168.001.104 will not work 192.168.1.104 will work.
Dear All, I wanna get the data from ind331 indicator(Mettler toledo) to SLC 5/05 CPU via Ethernet Ip using EEM instruction. The CPU=1747-L553...
2,171
Hi all, it's my first thread in this forum. I have problem with eem instruction. I try to communicate my slc 5/05 with alarm system and all time I...
3,791
Hi, I have facing a problem when i tried to link NS15 touch screen with CJ2M with built in ethernet port. The following address i have set...
8,866
I am trying to access PLC 317 via Ethernet but not success so far... don't know what wrong m doing, it shows connected but no ping. please see...
1,718
My computer can see the LOGIX processor and the Panelview 1000. The IP for Processor is 10.10.10.3 and Panelview is 10.10.10.2 with my laptop...
23
4,861
