Fmam89 Member F Join Date Aug 2015 Location egypt Posts 19 Aug 10, 2015 #1 Hi Guys , I have one little problem I try to write ladder diagram using Fc105 using simatic manager simulator and every time i make the program run this massage appear "" the statement are not being processed ""
beethoven_ii Lifetime Supporting Member B Join Date Nov 2006 Location Central England Posts 409 Aug 11, 2015 #2 is the block being called in OB1?
Fmam89 Member OP F Join Date Aug 2015 Location egypt Posts 19 Aug 11, 2015 #3 Yes I wrote the block digram in ob1
userxyz Member U Join Date May 2002 Location any Posts 2,768 Aug 11, 2015 #4 Fc You downloaded FC105 as well ? No jumps over the network ? CPU Runs ? Fmam89 said: Yes I wrote the block digram in ob1 Click to expand...
Fmam89 Member OP F Join Date Aug 2015 Location egypt Posts 19 Aug 11, 2015 #5 I download Fc105 the diagram is only one network contain FC105 cpu not run
Fmam89 Member OP F Join Date Aug 2015 Location egypt Posts 19 Aug 11, 2015 #6 i download fc105 the diagram is only one network contain fc105 cpu not run
userxyz Member U Join Date May 2002 Location any Posts 2,768 Aug 11, 2015 #7 Cpu Why is your CPU not in RUN ? Program is not running. Fmam89 said: i download fc105 the diagram is only one network contain fc105 cpu not run Click to expand...
Fmam89 Member OP F Join Date Aug 2015 Location egypt Posts 19 Aug 11, 2015 #8 https://www.facebook.com/photo.php?fbid=10206316963015791&set=a.1463793547660.2061652.1018126141&type=1&theater this link contain image show what happen exactly
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,301 Aug 11, 2015 #9 Click your BLOCKS folder and download Then stop and run buttons on plcsim What happens?
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,301 Aug 11, 2015 #10 my plcsim Last edited: Aug 11, 2015
Fmam89 Member OP F Join Date Aug 2015 Location egypt Posts 19 Aug 11, 2015 #11 Thank You JRW It work I download it from Blocks folder Thank you very much
JRW Member Join Date Jun 2002 Location South Carolina Posts 2,301 Aug 11, 2015 #12 Your welcome So FYI - fc105 was not downloaded
