Hi Everyone,
I had to replace PowerFlex 700 20BC085A0ANNANA0 with this one 20BC085A0ANNANC0. I set all (I think all) parameters the way they should be but the drive won't start the motor. It commucicates with the SLC 5/03 CPU using DPI Port 2 and that's what parameter 90 is set to. When I set this parameter to DPI port 1 and try to start the motor using HMI on the drive it works ok.
What am I missing. Are there any other parameters that have to be change?
Thank you
Thank you
