Problem with RSLinx for RSView-Micrologix 1500
Redland Brick
Mar 2005
24
Good Morning Guys,
I need to communicate with a Micrologix 1500,but I
am having trouble getting the RS-232 DF-1 configured,I keep
getting the following error when I use the Auto -Configuration.
-Unable to open the specified com port for configuration testing.
When I click OK I get-
-RSLinx has failed to configure the Com Port
Under Configured Drivers I Get-
-Port Conflict
I believe that the Com Port 1 is busy with something else,but
nothing else is open. I remember going into something and deleting RSLinxNG.exe somewhere but I forget where. Do you
folks have any ideas.
Thanks in Advance,
Generally the PIC driver is a favourite for port conflicts - have you looked at active drivers in linx .
What on earth are you doing "going in something and deleting RSLinxNG.exe somewhere but I forget where" , I might be missing something , but I'm not sure that is a good idea .
Don't forget to look outside RsLinx. What other communications software do you have. Palm software is one I see people miss a lot. As long as the little icon is in the corner, it will tie up the serial port by default.
Is it a real com port or a USB
RSLinxNG.exe is the executable for RSLinx Enterprise (for RSView Machine Edition). If you deleted it, you will have to re-install RSLinx Enterprise. What you should do, when trying to configure an RSLinx Classic serial driver (DF1, PIC) is go to Windows Task Manager, and stop RSLinxNG.exe. I hope that this is what you meant, rather than Delete. If you are trying to configure a serial driver in RSLinx Enterprise, you just need to stop/delete andy serial drivers you have running in RSLinx Classic, or shut down RSLinx Classic.
Hi, I am having a problem with the CCW v20.1 from Rockwell. It is the first time I am using it, as I used to work with Siemens or RsLogix, but...
2,088
Hello all. Just ran into a problem recently, and I’m guessing it might be somewhat common. I bought a license on 1/4/19 for RSLInx Classic –...
5,873
Hey all, I'm trying to connect to a CompactLogix controller in RSLinx inside a VM. When I connect to the controller, I can see the USB symbol pop...
17
7,884
Hi, It's seem like it's is easy to install RSlinx Enterprise, However i found some problems. I have : ---Windows 7 64bits ---Factory Talk...
1,710
I have problem about RSLinx Enterprise (FactoryTalk View SE) as follows; 1) I create Device Shortcut name (such as name "ABPLC") and match...
2,225
