Problems of RSView32 reinstall in new computer
Alex kwokman
Nov 2010
HK
When I install the RS view32 in new work station and already insert the USB Dongle key but that cannot communication to server. The project file was also selected. And the network config was checked in right IP and host name. Is i missing some procedure during installation?
The warning message "Data base conversion failed" was shown on the screen.
The existing work station is Dell of server grade config and the new work station is Lenovo desktop. Is there have any conflict on software transfer?
I'll be very thankful if any one can help me in this matter.
Best Regards,
Alex
What version of RSView 32 is on your old computer and what version is on your new computer.
What comms are you using.
Have you set up the paths in the nodes and possibly the channels.
What version of RSLinx do you have and version number.
Do you need to set up OPC in the RSLinx.
Provide some screen shots.
Ans: New and old computer is same ver. “RSView32 Version 7.20 (CPR7)”
Ans: PostgreSQL, ODBC data source, NTP client
Ans: I don’t know the meaning.
Ans: RSLinx Classic Gateway Version 2.50 (CPR 7)
Ans: Yes, is DDE/OPC config.
Version 6.30.17 very old Project has not used vba scripting prior to this problem Took the 6.30.17 project and put it into a 7.20 version...
5,107
Hi, On my current project i am using RSView32, RSLinx Classic OEM, and Control Logix. As of yesterday, everything was working fine. We had a...
3,555
I am having issues with a View32 project converted to FT SE Network. Some of the tags appear to be working fine while others are not. If there is...
4,420
I had a power outage, after restoration ALL the values on my display were missing. Currently everything has to be done manually. I am running a AB...
4,723
That such a dear friends. I have the following problem in the configuration of a computer server and a computer client or work station. The...
15,867
