RSView32 Problems
This is the problem:
I am using the Logix5555 (1756-ENBT\A L55)
Channel:
Network: TCP/IP
Primary Comm. Driver: AB_ETH-1
Meaasges: 3
Channel: 1
Active Driver: Primary
Node: (Direct Driver)
Channel: 1
Enabled: Y
Station: 130.130.130.2 (same as 1756-ENBT\A L55)
Type: "I am not sure" Options ( PLC-2, PLC-3, PLC-5, PLC- 5 (ENHANCED), SLC 5, SLC 5(ENHANCED) AND SOFTLOGIX 5)
Timeout: 3.000
Tag Database: Intact
Command Line: comstatuson
My primary comm driver keeps reseting to "None Loaded" everytime I restart. Plus it is defaulting to OPC Server with RSLinx OPC Server In-Process.
RSLinx RSWho I only have the TCP/IP driver configure (AB_ETH-1).
I pinged IP (130.130.130.2) and it replied. I can see all my I/O Modules and they are all browsing.
"This is drving me mad but I am loving it. I am really up to the challenge".
Thank Guys!
Channel: 1
Enabled: Y
Timeout: 3.000
Thank Guys!
It is my belief that you need to use an OPC driver
see the link below I think this may help you its from about the same time you first posted
http://www.plctalk.net/qanda/showthread.php?t=47690
Version 6.30.17 very old Project has not used vba scripting prior to this problem Took the 6.30.17 project and put it into a 7.20 version...
5,105
When I install the RS view32 in new work station and already insert the USB Dongle key but that cannot communication to server. The project file...
2,244
Hi, On my current project i am using RSView32, RSLinx Classic OEM, and Control Logix. As of yesterday, everything was working fine. We had a...
3,553
I am having issues with a View32 project converted to FT SE Network. Some of the tags appear to be working fine while others are not. If there is...
4,419
That such a dear friends. I have the following problem in the configuration of a computer server and a computer client or work station. The...
15,866
