Proface panel downloading
Jim G.
Nov 2007
Georgia
187
I have a line which uses 5 stations with a proface panel at each station. They are all networked together through Ethernet. They are communicating with a Yaskawa PLC. I need to add an alarm message at one of the stations and have it display on all the stations. I have GP-ProEX software. Under "Commn Settings" , I added the message I want to the panel I am working on. I can now transfer the project to the panel and get the alarm message on that panel. Do I have to do subsequent downloads to the other panels to get the alarm message there? Or does downloading to one panel send the common settings to the other panels as well? Thanks.
The alarm messages are stored in each panel so you would have to download the same updated app to all of them.
Make sure each one has the correct PLC communication data (IP address and port number)
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
345
Hello All, I am just starting to learn how to communicate with HMI's (Total Control Quickpanel/Proface) and some guidance would be very helpful...
5,622
S7-300 (CPU 315-2 DP) PLC works with AGP-3500T (ProFace) Operator Panel via TCP/IP. I suppose the panel performs some function, which normally...
1,720
Hi, I use many of PROFACE TOUCH PANEL product, type : GP477R-EG11. At the moment I have problem, with it. The problem when I want to open...
3,750
Hi, I've a Proface Touch Panel model AGP3400, Ethernet/IP communication. I've no real ControlLogix5000 to make a demo, I've developed PLC on...
3,730
