PROFIBUS: device independant
kalabdel
Feb 2015
Ontario
1,108
Hello everyone,
How true is PROFIBUS device independence. I have a Beckhoff BK3110 that I will replace with an SMC EX260 and I haven't been able to connect to the OMORON CPU C200HX to look at the code.
Both are PROFIBUS-DP, would removing one and plugging the other work with the existing address mapping?
One is an IO block and the other is a valve block
Right?
What are you trying to do exactly?
They are different gsd files. So they can not just be exchanged
Thanks JRW, I replied and I don't see my reply. I was having issues posting images and now I don't see my last post. I will try again.
I would like to replace the Beckhoff in the picture with an SMC 260-SPR8
Thanks JRW, it's not your phone I think the size of the image was too large and it's *large*.
I figured it was a lot more than in and out replacement and without beiing able to connect to the CPU it will not happen. I have to resolve my connection issues first.
Thanks a lot.
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
323
Hi, I'm rather new to siemens. I have a project were the plc needs to be upgraded, new code, ... The existing hardware needs to be reused...
2,800
Is there any way to get diagnostics info on device connected over Profinet/Profibus (communication with device fault) from PIW assigned to that...
2,491
Hello Guys, I have s7-315-2 PN/DP with integrated DP. I have no CP module. PLC should be DP master. ON other side there is basler device DECS250...
3,490
Greetings! I am curious if there is an easy and simple Profibus master device to check Profibus devices and cabling for operation. Obviously...
1,921
