Profibus DP between two S7-1200
mikla90
Jun 2017
Italy
20
Hi everyone. So, as I told first time I got here I'm a newbie in PLC programming so please be patient.
Here's the thing. For testing a device we make, I have to connect two identical S7-1200 CPUs via Profibus DP. Now, setting up the project was easy, just add the devices, the communication modules master and slave and then link the slave to the master.
The problem is when I go in the MainOB of the master and create a GET instruction in the properties section I can select the master, but not the slave! Or at least not via Profibus, only Profinet. Before getting on with memory and all the rest, why can't I see the slave even if it's connected and has a adress?
Attached a pic of the GET properties section.
Thank you!
My boss wants this, no chance of changing. When you say "just use the i/o" what do you mean? The master can read directly the i/o of the slave in its main OB?
Yes, both connected to the same subnetwork Profibus_1, with adresses 2 and 3. I even set up a couple of iSlave adresses to see if that changes something. But still nothing.
Edit: if you want some screenshot, just ask. It's easier if you ask what you want to see than me screeshotting every single thing...
Ok, when I try to compile the hardware I get an error on PLC1. Translated in english is something like "link partially specified. Partner interface missing."
Clealry, I missed a spot. So, this is what I did.
Create a new project, adding both PLCs and both interfaces, linking the slave to the master, checking network parameters (speed and so on), added a GET instruction in the master and got the error above. Then, when I try to compile I get that error. What did I do wrong?
Hello, I'm writing my first program for S7-1200 and have some problems with communication between CM 1243-5 and FC302 via profibus dp Is there a...
3,807
Hello Experts, I have two system one ET200S and another CPU 1513- PN which are 300 meters apart. Now i want to share data between these to...
2,469
I am not great with Siemens and Profibus so looking for some advice. I have a project where I need to communicate approximately 20 status words...
1,661
Greetings Can the Profibus network ، Schneider Premium PLC with TSXPBY100 Module was selected as Slave? I'm going SIEMENS PLC (S7-400) as master...
2,356
Hi, I wanted to establish a profibus communication between 2 plcs. One is S7 400 and other is S7 300 plc. Please let me know what is the right...
5,945
