Profibus DP to Compact Logix
Money4Nothing
Apr 2006
Longview, Texas
224
I have 3 VFD drives that can only communicate Profibus DP, and I want to control them with a AB Compact Logix controller. I can't find a Profibus DP master that can talk to AB DF-1 or Ethernet I/P on a Compact Logix. I don't want to have to upgrade to Control Logix just to solve this communication problem. Any suggestions on a solution to this?
Thanks in advance.
HI, YOU MUST LOOKING FOR PROSOFT PROFIBUS MODULES, THEY MADE A GREAT VARIETY OF THEM FOR AB, IM SURE THEY HAVE A PROFIBUS DP MASTER MODULE FOR COMPACTLOGIX. BUT YOU HAVE TO ADD THE PROFIBUS DP MASTER TO YOUR HARDWARE NOT VIA AB-DF1 OR ETHERNET, IF YOU WANT TO TRANSFORM PROFIBUS TO ETHERNET OR PROFIBUS TO SERIAL, YOU HAVE TO LOOK FOR A GATEWAY, WOODHEAD HAS SOMEONES.
CHECK THIS PAGE : http://www.prolinxgateways.com/mvi69_pdpmv1
OR CHECK THIS http://www.woodhead.com/products/automation/gateways/#5816
TAKE IT EASY MAN
JEJEJE
Hilsher
If you decide to go back to Profibus, Hilsher makes a Profibus DP master (and slave) card for the compactlogix/micrologix 1500 series PLCs. They are pretty easy to configure and work well.
Hi , has any one encoumtered the following problems when working with simovert masterdrive connected through profibus to compactlogix using...
3,349
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
199
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
97
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
116
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
329
