chavak
- Join Date
- Jul 2002
- Posts
- 750
I started to work with my first project using Profibus in Control Logix PLC [L61] using a Proface MV156 PDPMV1 card in slot 2. I had configured the PLC and MV156 + the slaves in the field. I was using the sample program as a guide from the Proface site.
I am getting responses from the field devices correctly on the tags of MV156 which is of SINT data types.
My devices are all integer data types. Do I have to copy each of the 2 tags to a int tag to get it combined? Is this the usual practice? Usually I use Alias the I/O tags to a more readable tags in my programs and use that tag name as my wiring labels. For example -
Local:2:I.Data[0] to I_2_0 which gives me I_2_0.0, I_2_0.1, etc as digital entities.
But I am facing difficulties for MV156 to Alias to an int tags as the base tag is SINT. Is there any better way to do this, rather than copying 2 SINT to an INT tag.
I can't use the Local:2:I.Data[0] tags where the Profibus Card is residing, because the values in it is blinking [going on/Off] - not sure why is it so? Any idea?
Thankyou
Best Regards
____________
Thankyou
Best Regards
____________
