I am trying to write some code using the AB CLX platform.
I have set up a small Profibus network with 3 devices attached.
My SST-PFB-CLX Scanner Module is located in Slot 2 of my rack.
Each device sends data in the form of a IEEE-754 Floating Point value using 5 bytes.
The first four bytes are used for data the 5th byte is used for device status.
The device status is not required.
Each device displays a value of 0 - 100% but the value that comes into the PLC is Eg. -16234 & 23908.
How do I get these to read in Engineering Units?
Can someone help!!
Can someone help!!
