Integration of Barcode Scanner (Microscan 880) with Control Logix Processor
Rajendra_Raja
May 2006
Dubai
In one of my project I need to integrate Bar code Scanner (Model: MS 880, Supplied by Microscan) with Control Logix Processor using Ethernet Network (1756-ENBT Module).
I need information about RSLogix software and Bar code scanner software configuration.
May be profibus
Not sure if you can link this scanner over ethernet of Control Logix.
May be using Profibus interface you can.
Arc
I am very familiar with the DH+ and DeviceNet interfaces to the MS-880, but I have not used the Ethernet interface. Although the website says it includes an Ethernet interface, I did not find a User Manual that describes it.
Call or e-mail MicroScan and talk to their technical support; I know those gentlemen personally and they will be able to help you out.
Ethernet/IP to Microscan bar code scanner
We manufacture an easy to use, reasonably priced product called DeviceMaster UP, which facilitates the exact connection you appear to be needing. Literally configures within minutes and communicates with any of the AB PLC's.
Contact me directly if you might be interested in additional details.
I thought I was nearly finished on this TIA Portal/s7-1212C project (famous last words)... Up until now, I'd developed the PLC/HMI such that the...
1,574
I require to interface a Honeywell 3310g fixed industrial barcode scanner with Delta DVP-SX PLC. The barcode scanner has a RS232 communication...
4,140
Hi, I am working on a machine tending application. Fanuc Robot with IR VIsion and Beckhoff PLC. I am trying to find any documentation on how to...
102
I want to program an Exor HMI using a Rockwell controller. However, when exporting the tag list from the controller and importing it into JMobile...
125
Hi all, I have a noob question regarding data handling from sensors. I understand configurations and I/O mapping sensor input/output variables...
226
