sanketsshirodkar
I require to interface a Honeywell 3310g fixed industrial barcode scanner with Delta DVP-SX PLC. The barcode scanner has a RS232 communication port. The data through the scanner will be transmitted as ASCII code on hyperterminal. I want to store the ascii data in a plc data register (D register) and perform some output function based on the data received from the scanner.
How can i read the ascii data from the scanner in the plc data register?
