Profibus minimum cable length 1m
Plc_User
Dec 2005
Belgium
317
I just saw a small film on youtube where they did an analasys of a Profibus network. Final reason for the problems seemed to be some stations that where connected with a Profibus cable of less then 1 meter.
What are your experiences with minimum cable length in Profibus or other causes for Profibus problems.
Thanks.
Thanks.
I always follow the 1 meter rule on any PROFIBUS DP installation. You won't see the difference on low bus speeds, but at speeds above 1,5mbps it will save you a lot of problems.
The main causes for PROFIBUS problems are terminator resistors (too many or few or on the wrong places), bad shielding/EMC and incorrect cabling (max length, spur lines, near power lines,...).
Do you still have that link for the Youtube video?
I read somewhere that the profibus cable between two nodes has to have a minimum length of 1 meter. Although I see a lot of panels with very short...
9,647
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
196
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
92
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
113
Hi, I am using TIA Portal V18. I have imported a (v5.7) SIMATIC manager project via device proxy. I have created a HMI project (TP700) in TIA...
327
