Minimum length of profibus cable
Plc_User
Dec 2005
Belgium
317
I read somewhere that the profibus cable between two nodes has to have a minimum length of 1 meter. Although I see a lot of panels with very short profibus segments. What could be the reason for this minimum, and what is your experience and opinion?
I take it you're referring to this note in the Siemens PROFIBUS network manual?
I specify 1m minimum length between nodes even though it can be a bit of a nuisance to lose the excess cable and keep the installation neat.
Well you can take the risk and use lengths < 1m. Our machines are fairly standard (electric wirering) and we tested it once and apply it ever since.
But keep in mind, when you're having an unstable bus be sure to check the cable lengths first. Even when diagnotics points in the oposit direction!
I just saw a small film on youtube where they did an analasys of a Profibus network. Final reason for the problems seemed to be some stations that...
4,530
Looking over the technical data for a PowerFlex 755 & noticed they specify a minimum enclosure volume for their drives: (1)When using a circuit...
553
Hi all, I am working with an IO link sensor (measuring current across motor)and need to read in and store the sensor values for 5 seconds, then...
1,223
Yes or now and if yes what would you include or test for as a minimum standard? I can think of things like DeMorgan's theorem Karnaugh maps -...
60
23,182
Hi all, I have a PID loop in an AB ControlLogix processor and what I'd like to do is make sure that it doesn't all the CV to fall below a certain...
1,469
