dustinbrubacher
I am investigating a profibus solution (in replace of devicenet) in a material handling facility.
The PLC details are:
-Controllogix L63 processor
-Prosoft MVI56-PDPMV1 profibus module
-Advantys STB IO (STB NDP 1010 or 2212)
-likely one 6 input card and one 6 output card per node for control stations (not defined yet)
-either Altivar 31 VFD (io hardwired) or Altivar 312 VFD with profibus adapter
-I am planning on running the network at 1.5Mbps with max 200m networks.
The profibus network will likely be 50% VFDs and 50% IO (i am assuming VFDs are Altivar 312 over profibus).
How can i estimate the network performance of this network? I can vary the number of nodes one a network to get a deterministic network scan time of about 20ms.
Typically, when comparing devicenet to profibus, which is better suited for a network like this?
Does profibus have the ability to only send data on a change of state like devicenet does?
any other info you can provide that would be useful would also be appreciated.
Thanks,
Thanks,
