Profibus, Omron PRT21 to PLC7
Nevyn
Jan 2012
Norway
21
When I search for answers I often come to this site. Although I don't always find what I need, there seems to be a lot of knowledgeable people here so I'll try this one for you all.
I have a Omron CJ2M CPU, with a CJ1W-PRT21 Profibus Slave. It is supposed to communicate with a Siemens PLC7 system, although it doesn't at the moment.
I thought the setup for the communication was mostly done at the Masters end (which sadly is outside of my control on this project). If I open IO Table and Unit Setup in CX-Programmer I can go into unit setup. All the options there are grayed out although I can see drop down menus with the settings I want to use. For example: I would like to change the "Input area code" from "No assignment made" to "EM Area Bank A", then I could gather all the signals there and cross-connect them to wherever I need to use them.
Have any of you guys set up a PRT21 before?
1. Is it all in the GSD file?
2. Are all the settings set at the master?
3. Or am I missing something here?
I've read trough the document W408-E2-02-X+PROFIBUS-DP+OperManual.pdf from Omron, and it tells me how many words I can use, which CIO I have available etc. but I find it lacking in how to actualy set up the PRT21 to work with any masters.
I also looked trough the CX-Integrator and found the logical choice for a master, which has a lot of settings. I could however not find the PRT21 Slave unit in the list of components there.
All hints, tips, suggestions or experiences from anyone that have tried this before is welcome.
-Nevyn
I know it is a relatively new product - to me anyway
Most Profibus devices are used with siemens
- I am busy tonight (Monday 23rd) but I will source the PDF and have a look for you
section 3 of the PDF gives you afair Idea
the slot you fit this card
And to rotary switch position
Are you programming the Siemens also?
load the GSD Files - then all should become clear
I have a cpu315-2 dp set up as the master and an Omron Prt21 card set up as a slave and i was wondering if there is a way to transmit a data block...
3,833
What is the difference between ths CS1W-PRM21 and C200H-PRM21? I am trying to setup my hardware in the PLC program but only see the CS1W-PRM21...
2,058
Hi I want to control omron f7 inverter with s7-300 plc with profibus. If someone made similar project, can u share? or some documents. I've...
5,957
Hi!! There is existing project Step 7 whith 20 frequency inverters Danfoss. Can I add to this project/real hardware 4 Omron frequency inverters? I...
5,105
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
198
