Profibus to Ethernet Gateway
ernitin29
Jul 2011
Jaipur
19
Hello Frendz,
I m going to do a new project to take my all extrusion machine parameters online for monitoring purpose using existing intranet network to route the display in manager's cabin.
I have a set up S7 200 PLCs with Profibus network and connected to OP 270 where complete controlling as well as monitoring is done by machine operator. What i am thinking that i have a free port on each PLC, so make the similar network and connect the last Porfibus DP connector (Like connected in my OP) in the port of Profibus to Ethernet adapter and take out the RJ45 plug from the Ethernet port of the adapter.
Then I will connect this Ethernet Cable into Main Server (with this server several PCs are connected). On this main server I will install my Application for monitoring and get the data from plcs into tags.
So is this Going to work?
Nitin
I apologize if this is the wrong forum to post this in. I am looking at upgrading some older PCs that are using Siemens CP5613 cards and was...
1,711
Hi guys, One of the remote (pump station) PLCs I'm replacing in a water project has an existing Profibus connection and the client wants us to be...
4,826
There are 4 DCS on profibus... I need to take total 1100 real data points from them for centralized monitoring purpose using Rockwell PLC or/and...
1,524
I am working on converting from a seimens micromaster 440 communicating by profibus to a Schneider Electric altivar 71 communicating over...
1,201
Hi All, I looking for easy solution for my task. My customer want to collect all scada visualisations to one PC. There are six PLC's(Siemens...
1,228
