Proficy Machine Edition 6.5 Custom Blocks
MadPLC
Nov 2009
Delta, BC
47
Hey Everyone
I'm new to GE PLC programming with Proficy and am having an issue I can't seem to figure out. I created a custom block with parameters and want to re use it throughout my program. The problem is when I use it more than once with unique tags it doesn't act as two seperate blocks, they work "together" so to speak. They have unique block names but they don't act independantly.
I guess my question is did I make this block correctly or do I have to create unique instances in the database before I can use it? There are unique instances as shown in screen two but they still don't seem to work independantly. I have attached screens but if you can help but need more info please let me know.
http://imageshack.us/photo/my-images/850/screen1ay.jpg/
http://imageshack.us/photo/my-images/707/screen2exx.jpg/
Yeah it's the clock kb article. I tried the knowledge base but wasn't having luck with my searches. What did you search for?
Thanks again
Symbolic variables! You need them. We use them, we call the User Defined Function Blocks/Objects and UDFBs or Objects for short. The PACs allow them not sure about older ones,I too am Noobie.
Judging from the pictures, the timer you are using in the UDFB is not part of the UDFB. Make the timer a member of type TON, then its name will appear in the same color as the other variables of the UDFB.
@dYoast
I think that got it. I guess using the same timer for all the instructions wasn't a good call.
Thanks for the help
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
109
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,381
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,184
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,031
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands...
2,026
