Proficy Machine Edition 7.0 & Windows 10
Jul 2017
Barbarano Vicentino
Hi All,
I installed Proficy Machine Edition 7.0 on a Customer's PC, as I did many other times with other Customers, in order to fix a small bug in PLC program; but once I rebooted, PME did not activate 4-day license as expected.
Then only difference between this and all other computer is the Operating System (Windows 7 instead of Windows XP).
Does anybody have an idea on how to fix or bypass this issue?
Thanks in advance.
Cheers.
I dont even know what you are asking.
PME 7 isn't supported on XP or Win 10 so you may have unexpected results wth either.
Contact GE for the proper version for the OS used, if you are an Integrator or OEM you should buy into thier Solution Provider program and they will supply you with any version of PME needed to support your customers.
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
111
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,381
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,190
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,031
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands...
2,026
