Proficy Machine Edition Out of memory
Aaron222
Apr 2022
NH
Hello all,
I have Proficy Machine Edition 9.5 running on a Win7 Enterprise laptop with 16GB of RAM.
I am attempting to upload from a QuickPanel Mini (CQPM3D200B2P-A). I made a new project with the correct Model chosen (QPM-3xxxx) and connected using a USB to serial adapter and the correct cable. I have successfully Uploaded and Downloaded with this setup with a spare unit on the bench using a single simple screen for testing.
I begin the upload and it starts properly with the screen going into transfer mode. There is a step where PME restarts the QuickPanel and just after that, I get a popup window titled "Proficy Machine Edit..." with the message "Out of memory." There is one box to click, if I click [OK] to dismiss the window PME is still showing "Uploading from QucikPanel" at the step "Reading Project Tags Data" and this will hang until I kill PME using task manager.
What is this Out of memory message telling me? I can't imagine it to be true but is the computer out of memory? This has been a show-stopper problem so far. I have an old laptop running Win95 with QD3.6 that I may be able to read the QP with and make a .proj file, but I don't see why PME wouldn't work. :confused:
Thank you
What SIM version do you have installed for 9.5?
There is a note in SIM 6 about an out of memory error for a download to a QP. It is possible an upload causes the same problem.
The latest SIM for version 9.5 is 28. I think the SIMs are cumulative.
You can download from: https://emerson-mas.force.com/communities/CC_Home
You will have to register to be able to download.
I should also mention something that I forgot, when uploading with the QuickPanel mini I have to open PME as Administrator or I will get "unable to create file" alerts in the message area and it will hang trying to upload. So add the step "Open PME as Administrator" in the first post.
I tried uploading from a QuickPanel Jr (CQPK3D200L2P-A) and had the same result, "Out of memory" at the same point in the upload process.
I upgraded the sim version from 16 to 28 using the software at the link you shared, thank you. I see the same message.
Does anyone know if this could be caused by the original builder not including the project file when downloading to the quickpanel?
As far as I know, if the OEM did not include the project file in his download, you get a message advising that, not the message you're seeing. At this point if cleaning the project build folders hasn't helped, I'd uninstall/reinstall Proficy Machine Edition.
Are you using the (recommended) 64-bit version of Windows 7?
I am using Win7 64 bit.
An update: I opened a ticket with Emerson and they remoted in to do a "clean uninstall" which included uninstalling PME and removing extra files and registry keys the uninstaller did not remove. Then a clean install of PME 9.5 and patch to SIM 28. Problem persists.
They also said this is a known issue that was patched in SIM 28 but tested on Win10. They did not know if the patch was tested on Win7. I am working on getting PME installed on a Win10 machine with a temporary 30 day license from Emerson to test this. I will share my results.
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
105
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,376
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,144
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,021
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands...
2,022
