proficy machine edition
Jun 2016
hosur
im new to GE fanuc PLC im using proficy machine edition 5 to modify the existing program, when im online im unable to see which bit is ON and Which is off. is there any settings in the software can some one help in this regard
In order to see the status of bits you must be in the "Logic Equal" state. Look in the lower border of the window toward the right side. Logic equal means that the program file on the computer running Machine Edition matches what is running on the PLC. If they are not equal you have to decide whether to extract the program from the PLC to Machine Edition(Upload) or send from Machine Edition to the PLC (Download).
Proficy machine edition
I uploaded the program from PLC only
When I go online I'm unable to see the status of the bits in rung ( green color highlight in rslogix )
What is the message regarding logic equality that I referred to in my earlier response? Does it say "Logic Equal" or "Logic not Equal"? Proficy Machine Edition version 5 is several years old, so it is possible there are issues between the version of the PLC firmware and version of Proficy. If so you may have to download the program you just uploaded in order to achieve logic equality.
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
108
Hi, I am still a beginner with PLCs and I have never worked with GE PLCs before so looking for some help. I am using GE Proficy Machine Edition...
1,380
I am trying to download version 9.8 of G.E.'s proficy machine edition, does anyone have a link to a download site?
5,180
Need to learn a few more tricks in Proficy Machine Edition. I don't use it often, but one of the first things I usually do when getting into a new...
1,027
I have a GEFanuc plc 90-30 that has dumped it's program and IP. The tool in PAC for setting a temporary IP is not available. The Offline Commands...
2,025
